Resizing control panel doesn't stick [Accepted]
When I make the control panel wider, I want it to remain wider when reopening.
Re: Resizing control panel doesn't stick
Hello!
Thank you for contacting TerraMaster!
Your suggestion about the control panel width adjustment has been relayed back to the product team. We will evaluate this requirement in detail and if it passes the review, it will be considered and scheduled in a future version update.
Thank you again for your support and suggestions! If you have any other ideas or questions, please feel free to contact us.
Thank you.
Maybe add a lock icon so you can lock if you want, and keep the control panel working the same for the rest.
F4-424 Pro, TOS 6.0.694
That goes for height too
Just in case the product team is too literal.
- CodeTheFuture
It would be great to have all Windows remember their X and Y top left position and also the Width and Height. If the window ever finds itself outside of the bounds of the current window then perform a window position reset.
This should go for all Windows in TOS where possible.
GREAT suggestion! This is really annoying have to resize windows many times when working within TOS.
