F8 Plus lost raid configuration
The machine is F8 Plus. I used an external hard disk box to mount 5 hard disks to create a traid. The built-in 8 SSDs are also traids. The machine crashed when transferring data from the storage pool. After multiple restarts, the storage pool of the external hard disk box disappeared. Now I can see the hard disk, but I can only recreate the storage pool and reformat the hard disk. Is there any way to rebuild the storage pool data? I checked the hard disks and they all showed normal without any errors.
- DonNikolaus
Re: F8 Plus lost raid configuration
Hello! Can you tell me how long the data has been lost? If it's been lost for too long I'm afraid it will be difficult to recover.liyuegun wrote: ↑24 Jan 2025, 23:46 The machine is F8 Plus. I used an external hard disk box to mount 5 hard disks to create a traid. The built-in 8 SSDs are also traids. The machine crashed when transferring data from the storage pool. After multiple restarts, the storage pool of the external hard disk box disappeared. Now I can see the hard disk, but I can only recreate the storage pool and reformat the hard disk. Is there any way to rebuild the storage pool data? I checked the hard disks and they all showed normal without any errors.
- DonNikolaus
Please reply me soon. So I can guide you right now.DonNikolaus wrote: ↑22 Feb 2025, 11:45Hello! Can you tell me how long the data has been lost? If it's been lost for too long I'm afraid it will be difficult to recover.liyuegun wrote: ↑24 Jan 2025, 23:46 The machine is F8 Plus. I used an external hard disk box to mount 5 hard disks to create a traid. The built-in 8 SSDs are also traids. The machine crashed when transferring data from the storage pool. After multiple restarts, the storage pool of the external hard disk box disappeared. Now I can see the hard disk, but I can only recreate the storage pool and reformat the Geometry Dash Litehard disk. Is there any way to rebuild the storage pool data? I checked the hard disks and they all showed normal without any errors.
