Hi there,
I recently set up a F4-424 with TOS6, and so far it works really well.
However, I'm having some issues with syncing my OneDrive folder.
I set up a one way sync to the root folder of OneDrive as it will just serve as a backup that syncs once a week.
The initial sync , however slow, worked but after finishing it seems that it just "stopped" somewhere along the way. It did sync all my folders and files in the root folder, but it Stopped during contents of the last folder. It synced 4 out of 12 subfolders or so...
Is there a limitation regarding maximum file count that can be synced at once? The folder in question is my camera upload from the phone with a few thousand pictures in total.
Cloud Sync of OneDrive - Limitations regarding Folder count?
- magnus4ever
Re: Cloud Sync of OneDrive - Limitations regarding Folder count?
No idea about OneDrive, but I sync close to a thousand sub-folders totaling 125GB to BackBlaze without issue.
Also, be aware that the sync period you chose does nothing if it is a one way upload sync. The sync will be live, every time a file is added or changed on the NAS it will by synced to the cloud. The sync period only relates to polling the cloud for changes if you have a two way sync, or a cloud down to NAS sync. TM support said that was the way it was designed.
- magnus4ever
Well, I'm happy to report it works now.
What did I do?
- Created a separate share on my main Volume just for Onedrive Sync
- Updated Cloudsync to newest version (recent update a few days ago)
What did I do?
