Portainer can't login post update
Discussion about Docker
warlock00
Australia
Post by warlock00 »
Updated Portainer today to 2.21.004. Can no longer login.
Message: Failure - Unable to retieve user details: Unauthorized
When I login. I can see that it partially succeeds.
The /api/auth endpoint is a 200 ok. Normally would fail here if you enter bad user/password.
But then the /api/users/me endpoint is 401 unauth.
I tried reinstall with full delete to no success. Which suprisingly preserved login which is scary if you want to reset login after forget.
F4-424 Max @ v6.0.794 - 2xNVME 4TB (Gen4x4) TRAID1 System/Volume1, 4xSATA SSD 4TB TRAID5 Volume2
Re: Portainer can't login post update
Your model number and TOS version please?
warlock00
Australia
Post by warlock00 »
Updating my bio! :D
F4-424 Max @ v 6.0.610
warlock00
Australia
Post by warlock00 »
This is strange, I swear I previously tried every combination of http/https, fqdn/ip and passwords.
Solution:
Password was reset to starting password :(
I logged in using http://ip...:8181/portainer (ie. not https://ip...:5443/portainer)
Win :)
Return to “Docker”
