Global SSL Guide
benno
Australia
Global SSL Guide
Post by benno »
I haven't had luck finding a tos geared guide to setup (excuse the lack of terminology) a reverse proxy/proxy.
AI correct in my understanding that
a) I can set something somehere so that all my services instead of being http://<ip>:<port> can be http://<server>.local<port> and
b) I can set an SSL for <server>.local so that I can use SSL across all services https://<server>.local:<port> without warnings everywhere?
I have installed npm and setup proxy hosts and ssl certs for the proxy domains but still get ssl warnings.
surely theres an easier way? Or isn't there...
Thank you, and happy new year :D
Re: Global SSL Guide
Your TNAS running TOS 5/6 does support connecting to a proxy server, please go to "control panel > network > proxy connection".
To set up a reverse proxy, please go to TNAS community place to down load a third party app:https://tmnascommunity.eu/download/taxy/
benno
Australia
Post by benno »
Cheers Roy, I didn't get pinged of a reply on this thread! Installed taxy and posted for support, errors and all. It would be nice for a terramaster guide just the same. Easy to follow, step by step.
