F4-424 disks not added to storage pool
mitchr
Post by mitchr »
I have 2 16tb drives in my storage pool. adding 2 18tb drives to the pool. I go through the storage pool edit/add hard drives to raid. I add hdd3 and accepts the configuration. after waiting a day, the disk shows HDD3 (system drive), but does not show in the storage pool. doc says I have to wait until it show up to add the HDD4.
should I still be waiting or is there hidden documentation that I need to do something else?
mitchr
Re: F4-424 disks not added to storage pool
Post by mitchr »
I'm guessing that it is adding this to the storage pool. I logged in through ssh and did an iostat on the drive and can actually see it writing to the drive, if not very slowly. so I will be patient. probably take a few days.
You would think they would change the status in the storage pool, but no.
GevinKe
Post by GevinKe »
mitchr wrote: 17 Jan 2025, 04:28 I'm guessing that it is adding this to the storage pool. I logged in through ssh and did an iostat on the drive and can actually see it writing to the drive, if not very slowly. so I will be patient. probably take a few days.
Hello, you can view the array synchronization process by executing the "cat /proc/mdstat" command. If you are adding storage devices to the storage pool, you can directly see the synchronization progress and speed with the help of this command.
mitchr
Post by mitchr »
all the definitions for /dev/mapper/vg0-lv0 are gone after I rebooted
F4-424. I have 4 disks in the volume group and all the definitions are
gone.
I have gone through the
viewtopic.php?f=79&t=2575 and when doing
the btrfs check /dev/mapper/vg0-lv0 it cannot be found.
any help would be appreciated.
Mitchell Mikesell
F4-424 Pro
tos 6.0.610-00165
GevinKe
Post by GevinKe »
mitchr wrote: 24 Jan 2025, 04:27 all the definitions for /dev/mapper/vg0-lv0 are gone after I rebooted
gone.
Mitchell Mikesell
F4-424 Pro
tos 6.0.610-00165
Hello, Please generate and download the log report package in TOS > Technical Support > Report Issues, and then send it to our support mailbox (support(at)terra-master.com) for inspection.
If you can't send the zip package because it's too big, you can use the netdisk share link. This may allows us to better and faster judge the problem and come up with a solution.
