F4-210 slow file read
jl434
Post by jl434 »
I have F4-210 (1G) with 2 * Seagate IronWolf 4T running in RAID0, it can reach 110 MB/s write to F4-210 for single large file (50G); however, it is only around 50 MB/s read for the same file from the NAS.
Re: F4-210 slow file read
May I know what file service you used?
jl434
Post by jl434 »
TMroy wrote: 13 Aug 2020, 23:48 May I know what file service you used?
Hi TMroy,
SMB
This lower than the normal rate, there are many facts which can lead to low rate. Please check it our refer to below article.
viewtopic.php?f=75&t=527
jl434
Post by jl434 »
TMroy wrote: 14 Aug 2020, 22:53 This lower than the normal rate, there are many facts which can lead to low rate. Please check it our refer to below article.
Hi TMroy,
I used the CAT6 cable directly connect to F4-210, but no different: write: around 110 MB/s, read: around 50 MB/s
I checked both IronWolf hard drives, they are healthy.
jl434
Post by jl434 »
btw, I did test in two different computers, both with gigabyte network adaptor, but no different for the read (around 50 MB/s)
Thank you for your information. We will try to duplicate your case here and will let your know.
Return to “File Services”
