VPN Server working but not showing connected user
rvescovi
Italy
Post by rvescovi »
With the newest TOS6 610 I was able to download the config file / cert of openvpn, set-up a windows client connection to the NAS and access it.
I tested and I'm pretty happy for the performance (comparing to slow tnas.link). Now I want to leave open but I have no idea how to check if there are malicious connection or tentative in place to the VPN server. To be honest when I'm connected, the "VPN Server app" didn't show active connection and LINK section is empty too.
Are there also some best practices for configuring NAS VPN Server in the more robust way?
Thanks.
EthanLiu
Re: VPN Server working but not showing connected user
Post by EthanLiu »
rvescovi wrote: 16 Jan 2025, 00:48
Thank you for your feedback. The issue you mentioned is a known problem and will be fixed in subsequent versions. Please be patient and await the release of future versions!
Return to “Network”
