Portainer access denied adding local environment through sock
rvescovi
Italy
Post by rvescovi »
After today updates of TOS to 610 and PORTAINER TOS APP 2.24 I still have the same issue "access denied" error which prevents me to add LOCAL environment accessing the /var/run/docker.sock within PORTAINER.
The unique way to use PORTAINER APP is to install the AGENT in docker through port 9001.
Is there anyone that correctly installed PORTAINER APP? I tried also creating the docker group adding my superuser but still have the error.
Thanks.
TMlinda
Re: Portainer access denied adding local environment through sock
Post by TMlinda »
rvescovi wrote: ↑15 Jan 2025, 20:41
Currently, there is a problem that Portainer cannot connect to Docker after SPC is enabled. This problem will be fixed in the next version. It is currently recommended that you turn off SPC before using Portainer.
rvescovi
Italy
Post by rvescovi »
I understood, thank you very much for the answer.
Return to “Others”
