Search by folder names  [Accepted]
Already accepted requirements or suggestions.
AES
Post by AES »
If you go into the Search application and enter the name of a folder that is on the disk and indexed, it will not find it. Please add search by folder names to the standard search.
Perhaps it is somewhere in the advanced search, but it seems to me that it should be in the default search.
TerraMaster F8, TerraMaster F2-425, Syno 218+
Re: Search by folder names
Thank you! we will add it to the list.
kurisutofa
France
Post by kurisutofa »
Hi, please implement this function. Everything is organised by folders in my data management. Thanks for your work
Return to “Accepted”
