Virtualbox Windows 11 pro - Display Flickering
JoergK
Germany
Post by JoergK »
Hi guys,
I am running a virtualbox VM of Windows 11 pro on my F4-424max.
My main goal is to replace my 2nd physical Windows 11 PC.
From my main Windows 10 PC I access the VM with Windows Remote Desktop Tool.
All devices sit in a high speed LAN.
My issue:
The RDC session shows flickering of the display which is very annoying.
System Settings: 10gb RAM, 8 cores
Display Settings:Video Memory 254 (max), VBoxSVGA, 2D disabled
I tried many other combinations which did not help to fix the flickering issue.
Does anyone saw same issue and found a resolution of it? Great if you can share...
All best from Germany
Jörg
Return to “Virtual Machines”
