Please add "Temperatures" to System Info > Resource Monitor [Accepted]
- CodeTheFuture
Please add the logging of all temperatures across the system to the System Infomation > Resource Monitor feature for the next release. Thanks!
Re: Please add "Temperatures" to System Info > Resource Monitor
You could just open the desktop widget to see temps.
{You don't say which TOS version?}
- CodeTheFuture
F4-424 PRO running TOS v6.0.577-00166.
That's a terrible idea as the Desktop widget does not perform logging of historic data as the Resource Monitor does via Settings > Enable Continuous System Resources Monitoring or if the desktop is powered off.
If you arn't aware of this feature and it's purpose, it might be best to avoid commenting on suggestions around it unless it's to add your support.
Oh, so sorry. I didn't realise that you always expect to get positive response and support. This is the internet after all. I was just pointing out an obvious answer that might just help others if they want a quick solution. I don't need temp logging and I think it will add more clutter to an already cluttered interface. It also adds to the system load and (probably) more frequent logging may stop systems sleeping (Thinking of HDD here).
We will forward your suggestion to our product manager for discussion. Thank you!
- CodeTheFuture
I'm very disappointed that we have just had a major TOS update and this feature wasn't included.
I really hope minor features such as this that the public requires arn't constantly ignored and do actually make it onto the next version.
This change does not affect the main functionality. After discussion, we will not apply it to upcoming minor version updates. Please wait for future version updates.
