T12-500 - fan connectors
pl790012Kn
Netherlands
Post by pl790012Kn »
I have a T12-500 Pro and wanted to see if the 3 Snowfan 12 volts 92cm fans could be replaced.
The Noctua NF-A9 PWM (92cm 4 pins) seems to fit, but the connector is not the same. The TerraMaster is expecting JST XH (2.5mm) header, which is different than the Noctua header.
The Noctua has this wiring (as per https://noctua.at/pub/media/wysiwyg/Noc ... _paper.pdf): blue, green, yellow, black
I had to remove the Noctua header and replace with a JST and change the wires to the following: black, yellow, green, blue
Not sure why it has to be reverted, but it worked (I tested it).
Maybe this will help someone in the future.
Related thread:
viewtopic.php?t=1272
Re: T12-500 - fan connectors
You are lucky you get 4 wire colours. The smaller units I have examined get black+black+black+black.........
Frustrated Beta Tester!!!
