Installing software from the ssh console
Hausmeier
Greenland
Post by Hausmeier »
Hey, I didn't know where to put my question but I thought this section here is closest.
I just would like to know how you can install additional software when you are loggin via ssh. No packet manager (e.g. apt-get) was found. So how do I install software or is there no way doing it?
Thanks in advance for your help
Re: Installing software from the ssh console
What model you are using and what version of TOS running on it? If you run TOS 6, then you can manage your app with apt tool.
Hausmeier
Greenland
Post by Hausmeier »
TMroy wrote: ↑04 Jan 2025, 14:03 What model you are using and what version of TOS running on it? If you run TOS 6, then you can manage your app with apt tool.
I am usuing the f4-424 and the TOS is unfortunately 5.1.145
TMpzhen
Post by TMpzhen »
Upgrade to TOS 6.0 to use the apt tool to manage your app.
Hausmeier
Greenland
Post by Hausmeier »
TMpzhen wrote: ↑05 Jan 2025, 13:22 Upgrade to TOS 6.0 to use the apt tool to manage your app.
Sure this works. It says that the software is the latest version...
Return to “Initialization”
