I must be doing something wrong here. Hardware is a F2-423 with a pair of 8TB drives in Raid1 (not TRAID), latest TOS5 installed. I want to add an external USB disk so I can backup one of the volumes in Storage Pool 1 before I add a 256gb SSD and install TOS6.
I have a 4TB drive in a USB3 enclosure, so I plug it into the TNAS and it appears as USB Disk_sdc. So far so good. There's an icon on the top menu bar that says 'USB Disk'.
I create Storage Pool 2 on this disk as 'Single Disk' and the pool is created but... it disappears. I can't create a new volume. I still only have 1 storage pool. In an SSH session I can see that the drive exists and has 4 partitions on it
sdc 8:32 0 3.7T 0 disk
|-sdc1 8:33 0 285M 0 part
|-sdc2 8:34 0 7.6G 0 part
| `-md9 9:9 0 7.6G 0 raid1 /
|-sdc3 8:35 0 1.9G 0 part
| `-md8 9:8 0 1.9G 0 raid1 [SWAP]
`-sdc4 8:36 0 3.6T 0 part
`-md1 9:1 0 3.6T 0 raid1Is there something I'm missing? I'm slightly bothered that md8 and md9 are part of Storage Pool 1, and if I unplug the drive and reboot the console tells me it's degraded md8 and md9 and repairs them.
This is the full output of lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 7.3T 0 disk
|-sda1 8:1 0 285M 0 part
|-sda2 8:2 0 7.6G 0 part
|-sda3 8:3 0 1.9G 0 part
`-sda4 8:4 0 7.3T 0 part
`-md0 9:0 0 7.3T 0 raid1
|-vg0-lv1 252:0 0 5.3T 0 lvm /Volume2
`-vg0-lv0 252:1 0 2T 0 lvm /Volume1
sdb 8:16 0 7.3T 0 disk
|-sdb1 8:17 0 285M 0 part
|-sdb2 8:18 0 7.6G 0 part
|-sdb3 8:19 0 1.9G 0 part
`-sdb4 8:20 0 7.3T 0 part
`-md1 9:1 0 3.6T 0 raid1 Cheers
Witchy
*edit* I've noticed the dmesg output matches md1 being a single 4TB drive, with md0 being Storage Pool 1 and its 2 Volumes.
[81536.792777] sd 3:0:0:0: [sdc] Spinning up disk...
[81537.899269] .ready
[81537.899544] sd 3:0:0:0: [sdc] Very big device. Trying to use READ CAPACITY(16).
[81537.899691] sd 3:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[81537.899722] sd 3:0:0:0: [sdc] 4096-byte physical blocks
[81537.900088] sd 3:0:0:0: [sdc] Write Protect is off
[81537.900105] sd 3:0:0:0: [sdc] Mode Sense: 47 00 00 08
[81537.900458] sd 3:0:0:0: [sdc] Disabling FUA
[81537.900474] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[81537.970451] sdc:
[81537.982006] sd 3:0:0:0: [sdc] Attached SCSI disk
[81539.039284] nfsd: last server has exited, flushing export cache
[81540.285187] NFSD: Using UMH upcall client tracking operations.
[81540.285220] NFSD: starting 90-second grace period (net f0000000)
[81633.584287] nfsd: last server has exited, flushing export cache
[81633.927717] sdc:
[81634.757448] NFSD: Using UMH upcall client tracking operations.
[81634.757480] NFSD: starting 90-second grace period (net f0000000)
[81635.337288] sdc:
[81647.419001] udevd[16510]: error opening ATTR{/sys/devices/virtual/block/md1/md/sync_speed_min} for writing: Permission denied
[81647.419061] udevd[16510]: error opening ATTR{/sys/devices/virtual/block/md1/md/sync_speed_max} for writing: Permission denied
[81647.471970] md/raid1:md1: active with 1 out of 1 mirrors
[81647.472012] md1: detected capacity change from 0 to 7791650816
[81732.874799] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[81732.953131] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
