Loosing Connection on a daily basis?
thefoxes
Post by thefoxes »
found this issue on another post thats now closed
Running 5.1.67 and i have to reboot my terramaster everyday to reconnect the mapped network share on a F5-221. It did not did this previously on version 4.x. I recently updated to 5 x with larger partition . Any help would be appreciated
Re: Loosing Connection on a daily basis?
If you have the required (nominal) 8GB system partition, you should be able to update to higher versions of 5.1 which includes lots of updates from 5.1.67. Check the release notes at: https://support.terra-master.com/posts/ ... ease_notes which have some (limited) info or the update threads on forum to access download links. Tos5.1 does not push update notifications to the NAS; you have to do it manually.
Frustrated Beta Tester!!!
thefoxes
Post by thefoxes »
Thanks Gremlin i will check it out
Return to “Network”
