I have 3 Gdrive accounts that i locally sync on my Synology nas.
FYI i’m migrating from DSM to TOS 6. But one thing keep me from ditching my old Synology.
On DSM i use CloudSync to locally sync 3 Gdrive account from / meanning that i got every files and folders created on Gdrive automatically synced locally and vice-versa.
The problem with CloudSync on TOS 6 is :
I can’t have more than 1 Gdrive account that sync from /. When i create the sync task for the second Gdrive account i got this error message : Sync task (task name) creation failed (Error : Remote Path AlreadyExists)).
For my usage TOS 6, CloudSync can’t do it, so i tried another way (Remote folder). But this time i found that i can’t mount at root a Gdrive remote folder. It must a be a subfolder, so TOS 6 Remote folder is no use for my needs.
I am now in a process of doing my own BiSync task using Rclone on Ubuntu. It work’s but it’s a shame that i can’t use TOS 6 for that.
David
Sync multiple Gdrive accounts vs TOS 6
Re: Sync multiple Gdrive accounts vs TOS 6
I do have the same problem, That is to say I can't chose the root directory as starting point. Very annoying.
Jirre
Jirre
Yep, would it be nice if we can remote mount at root.
Thank you for your feedback. We will evaluate this issue.
