f2-221 and TOS 6
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
Taillandier
Virgin Islands (USA)
f2-221 and TOS 6
Post by Taillandier »
Hello
I would like to know if my terramaster F2-221 is compatible with TOS 6 ! my version is 5.1.67
In case my tnas is compatible, which version should I install.
Thank you
IrisLi
Re: f2-221 and TOS 6
Post by IrisLi »
Taillandier wrote: ↑29 Dec 2024, 00:35
At present, the 221, 421, and 422 series models do not support updates. We will gradually release updates for the 221, 421, and 422 series models. Please pay attention to the update notifications.
You can upgrade to the latest TOS5 system using 5.1.145.
Taillandier
Anyway, thanks for the answer!
A little disappointed not to be able to update to TOS 6 (I love the new features!!)
Well I'll take care of 5.1.145
I'll have to be patient and it's going to be hard ;-))
(Why don't we see the latest updates in https://support.terra-master.com/downlo ... uct=F2-221) 5.1.145 is not there?
Thanks again.
Taillandier
Taillandier wrote: ↑29 Dec 2024, 20:46
You will have to go to the Updates section of this forum and find the relevant links to the update files that you need to download for manual install (observing the various warnings and caveats for the relevant update(s)).
{TM appeared at some point to paint themselves into the proverbial corner by needing an increased os partition size without there being a mechanism available to actually increase it without reformatting drives. They then did it again with the final releases to TOS6 by rewriting the file systems. It would be nice if someone told us WHY these models cannot be updated - rather than some vague long drawn out intimations that they might be up-dateable. It is clear some of these models are OK with TOS6 because (a few?) users who went via the Beta root have updated successfully. Then, of course, the Beta files were removed. Talk about SNAFU - younger readers may need to look that up but should proceed with due caution ;) }
Frustrated Beta Tester!!!
Return to “Compatibility”
