docker checkpoints and enabling experimental features in docker server
Discussion about Docker
jdesbonnet
Ireland
Post by jdesbonnet »
I'd like to experiment with docker checkpoints which requires that the docker server has experimental features enabled. I've followed the docker documentation and added file /etc/docker/daemon.json with contents: {"experimental": true}. I have restarted the docker service (and rebooted to be certain). Yet "docker info" still reports " Experimental: false". I've got a Terramaster F8 SSD Plus running TOS 6.0.577. The docker was installed via the TOS Web UI (Docker server version: 20.10.17). Any ideas how to enable experimental features on docker?
TMtina
Re: docker checkpoints and enabling experimental features in docker server
Post by TMtina »
jdesbonnet wrote: ↑27 Dec 2024, 06:37 I'd like to experiment with docker checkpoints which requires that the docker server has experimental features enabled. I've followed the docker documentation and added file /etc/docker/daemon.json with contents: {"experimental": true}. I have restarted the docker service (and rebooted to be certain). Yet "docker info" still reports " Experimental: false". I've got a Terramaster F8 SSD Plus running TOS 6.0.577. The docker was installed via the TOS Web UI (Docker server version: 20.10.17). Any ideas how to enable experimental features on docker?
You need to modify the daemon.json file located in the /Volume*/@apps/DockerEngine/conf/ directory, rather than the /etc/docker/ directory.
Return to “Docker”
