[ MiniQR ] A customizable QR code generator to create beautiful and unique QR codes.
About: https://github.com/lyqht/mini-qr/tree/main
Category:
Applicable models: x.64 series, arm series
Applicable TOS6: 6.0.124 or later versions
Applicable TOS7: 7.0.0124 or later versions
App download: https://tmnascommunity.eu/download/MiniQR
Required packages:
NodeJS22
TOS6 & TOS7: click on Support & Help from app description inside the App Center
benbenben
Israel
Re: [ MiniQR ] A customizable QR code generator to create beautiful and unique QR codes.
Post by benbenben »
does not run
installed the NodeJS20 dependancy, still wont run
the start_log details:
21/06/26 09:39:18 Will use /Volume1 to store config files
21/06/26 09:39:18 The main volume is /Volume1
21/06/26 09:39:19 Config folder will be created /usr/local/@APP_CONFIG/MiniQR
21/06/26 09:39:19 config symlink doesn't exist, will be created
MODCONFIGPATHHOME=/home/ben/MOD_CONFIG/MiniQR
MODCONFIGPATH=/usr/local/@APP_CONFIG/MiniQR
MAIN_VOLUME=/Volume1
HOME_VOLUME=/Volume1
MiniQR service is not running, will start it now
 SUCCESS!
/bin/bash: line 1: exec: http-server: not found
21/06/26 09:39:36 Will use /Volume1 to store config files
21/06/26 09:39:36 The main volume is /Volume1
21/06/26 09:39:37 Config folder exist at /usr/local/@APP_CONFIG/MiniQR
 SUCCESS!
22/06/26 00:59:19 Will use /Volume1 to store config files
22/06/26 00:59:19 The main volume is /Volume1
22/06/26 00:59:20 Config folder exist at /usr/local/@APP_CONFIG/MiniQR
 SUCCESS!
22/06/26 01:07:07 Will use /Volume1 to store config files
22/06/26 01:07:08 The main volume is /Volume1
22/06/26 01:07:08 Config folder exist at /usr/local/@APP_CONFIG/MiniQR
 ERROR!
25/06/26 08:42:42 Will use /Volume1 to store config files
25/06/26 08:42:42 The main volume is /Volume1
25/06/26 08:42:43 Config folder exist at /usr/local/@APP_CONFIG/MiniQR
 SUCCESS!
25/06/26 08:45:39 Will use /Volume1 to store config files
25/06/26 08:45:41 The main volume is /Volume1
25/06/26 08:45:52 Config folder exist at /usr/local/@APP_CONFIG/MiniQR
 SUCCESS!
25/06/26 09:35:20 Will use /Volume1 to store config files
25/06/26 09:35:20 The main volume is /Volume1
25/06/26 09:35:20 Config folder exist at /usr/local/@APP_CONFIG/MiniQR
 SUCCESS!
28/06/26 18:17:02 Will use /Volume1 to store config files
28/06/26 18:17:02 The main volume is /Volume1
28/06/26 18:17:03 Config folder exist at /usr/local/@APP_CONFIG/MiniQR
 SUCCESS!
would appreciate some fix for that, thanks!
Updated to 0.31.0, now require the latest version of NodeJS22.
Added TOS7 version for both x64 and arm NAS models.
