Dashboard does not correctly reflect rebuild status (6.0.555)
I was thinking the array rebuild was stuck (added 6TB drive to Traid). :cry: But it wasn't :mrgreen:
Re: Dashboard does not correctly reflect rebuild status (6.0.555)
Due to the limited display space on the dashboard, some information is simplified.
I was not worried about "simplification'; merely that, unlike all the other widgets, the Volume status does not update during a rebuild
Did you mean the status in widgets does not update even if the resync done?
After the resync everything is normal. It is just during the resync - the dashboard being my primary source of info while system is working.
Thanks.
