Initialisation Windows PC, Login does nothing
I've just started with a new F4-210, Installed 3 x 2TB drives and started it up. It is attached to my network which is connected to the internet. I have installed the PC application and it finds the TNAS device. I then press Login and absolutely nothing happens. My browser does'nt find it either. Where do I go from here.
Re: Initialisation Windows PC, Login does nothing
Change your default web browser to google chrome, Firefox or safari, or input the TNAS IP address in google chrome browser address bar.
OK thanks, was using Microsoft new edge, Chrome seems to work. Mind you so should pressing login from TNAS PC according to the instructions
i am using Edge and it works fine with my F4-210.
American Flyer, to Lionel HO then AHM and Blue box. Now in N scale do to space. Computers started with Ti99A and the C-64, went to PC and now use a NAS!
Microsoft Edge works fine for me also. But be sure to put :8181 at the end of the IP address, at least for the first time you connect. It's seems strange, but for me, when I connect for the first time from Edge or Firefox, it fails without the :8181 at the end if the IP address, for example 192.168.1.111:8181. I guess TOS uses port 8181 for the connection.
