Invisible users
Snakebyte
Invisible users
Post by Snakebyte »
Is there a way to see application users, as they don't show up in the user list in TOS 6 and aren't removed when the application that created the user is uninstalled?
Snakebyte
Re: Invisible users
Post by Snakebyte »
I forgot to add that the only place you can see them is:
Control Panel - Shared Folder - Select a folder - Permissions drop-down - Application User
Snakebyte
Re: Invisible users
Post by Snakebyte »
And if anyone can show me where the edit button is on this forum, I'd be grateful.
app.php/help/faq#f2r1
How do I edit or delete a post?
Unless you are a board administrator or moderator, you can only edit or delete your own posts. You can edit a post by clicking the edit button for the relevant post, sometimes for only a limited time after the post was made. If someone has already replied to the post, you will find a small piece of text output below the post when you return to the topic which lists the number of times you edited it along with the date and time. This will only appear if someone has made a reply; it will not appear if a moderator or administrator edited the post, though they may leave a note as to why they’ve edited the post at their own discretion. Please note that normal users cannot delete a post once someone has replied.
Re: Invisible users
I think I have only seen an edit button once.
Frustrated Beta Tester!!!
