Transmission change folder
Transmission, qBittorrent, Aria 2 download applications
vignatiev
Post by vignatiev »
Hello!
I've downloaded Transmission from AppCenter. The first time I downloaded torrents to an external HDD, the path was `Volume1/@usb/usbshare_sdd1/media/folder`. Later I've bought an internal HDD for downloads and want to give up external storage. When trying to transfer to internal HDD Transmission gives an error. If I start downloading to the internal HDD, I get an error and the download pauses. How can I fix it? I saw a similar 2023 thread on the forum, are there any changes?
Target path is `Volume2/media/folder`. This directory is already added to the shared folder. There is no separate group.
F4-424, TOS 6 6.0.555
F4-424
vignatiev
Re: Transmission change folder
Post by vignatiev »
I've notice one thing. If I have subdirectory in shared folder – it unavailable. For example I've created "test folder" in "public" (default shared folder). There is no "test folder" in "public" in Plex Media Server (from App Center) when edit library.
F4-424
vignatiev
Post by vignatiev »
I suspect this is the reason why I can't download or move/copy already downloaded data from external HDD to internal. How can I make subdirectories in shared folder visible to applications?
F4-424
Phyllismapes
Post by Phyllismapes »
Do you succeed in fixing this error? I'm facing a similar error and don't know how to handle it.
vignatiev
Post by vignatiev »
Phyllismapes wrote: 07 Feb 2025, 14:31
I've installed transmission via Docker and bind folders from Volumes.
F4-424
Return to “Download”
