Remote access - Unable to connect to VPN server
section94
Greece
Post by section94 »
I have been trying to find a way to remotely connect to my F2-423 from outside my network. TNAS.online works fine for general access, file transfers etc. but videos are unplayable (immense lag and buffering) and a media server accessible from outside my LAN was the main reason I got this NAS. So lets get to the problem part:
I am using a 5G router and unsurprisingly my ISP uses CGNAT which means no outside access. Googling and asking around I was recommended to use a VPN server so I downloaded the VPN server app from TOS. I had already set-up a DDNS too if that matters at all. But I just can't get any client to connect to the VPN server no matter what protocol or settings I use. I already port forwarded the PPTP port to the local IP of my NAS. Every time the connections fail regardless of platform (tried from 2 different PCs and an Android phone). And now I am thinking this whole thing is dumb because I have to use the WAN IP of the router to connect to the VPN anyway which as previously mention is behind CGNAT. So how is the VPN server even a solution to this problem if I can't connect anything to it?
I am sure I am getting something wrong here so any help figuring it out would be appreciated.
bugacha
Algeria
Re: Remote access - Unable to connect to VPN server
Post by bugacha »
The easiest would be to setup Tailscale.
section94
Greece
Post by section94 »
bugacha wrote: ↑06 Dec 2024, 22:23 The easiest would be to setup Tailscale.
Terramaster support also said the same but I have no idea how to use that. Guess I have more reading to do now...
But still if anyone has thoughts about the VPN server let know.
section94 wrote: ↑06 Dec 2024, 21:32 And now I am thinking this whole thing is dumb because I have to use the WAN IP of the router to connect to the VPN anyway which as previously mention is behind CGNAT. So how is the VPN server even a solution to this problem if I can't connect anything to it?
You are right, A local VPN server is not a solution unless ...
IPv6? (each machine should have unique identity on line)
Get a fixed IP from ISP. (Which is what I do, but not for VPN necessarily) Mine costs about £2/month add on.
A lot of ISP's have gone CGNAT route. {Same for mobile phone co's if anyone thinks that might be a solution - I have a cellular connection in event of broadband going out but it's no joy for inbound.}
Tailscale seems like a reasonable solution as it does bypass CGNAT and port forwarding. I'm sure there may be other similar services - maybe more local to you? And I believe Tailscale uses Wireshark.
section94
Greece
Post by section94 »
Gremlin wrote: ↑06 Dec 2024, 23:58
Thanks for making it clearer. I know very little about networking in general as you can probably tell so my next noob question is: How would I get an IPv6 address?
section94 wrote: ↑07 Dec 2024, 01:40
Your isp either supplies it or it does not. Depends on whether they have adopted the newer protocol and whether your intermediate equipment (router, switches, etc) support it.
section94
Greece
Post by section94 »
Gremlin wrote: ↑07 Dec 2024, 02:53
I am not getting one with my current ISP but I am about to switch soon to one I already have on my phone and this one gets both IPv4 and IPv6 according to whatismyip. If all goes well with this, do I have to force the router somehow to only get the IPv6 in my APN settings?
section94
Greece
Post by section94 »
UPDATE:
Installed Tailscale on the NAS, my phone and my laptop and even that can't connect directly to the NAS (when I ping it, it pongs back only through relays and then says "direct connection not established)
bugacha
Algeria
Post by bugacha »
section94 wrote: ↑07 Dec 2024, 16:25 UPDATE:
Did you configure exit node ?
section94
Greece
Post by section94 »
bugacha wrote: ↑07 Dec 2024, 17:20
Can't figure out how. I want to do it on the NAS. On the console its says "Re-run tailscale up with the --advertise-exit-node flag to enable this option." Where do I do that?
Return to “Network”
