Crontab entries lost after reboot
digdug
Post by digdug »
Changes to the crontab are lost after reboot. Is there a workaround?
In TOS in contrast to other NAS OS, I could not find anything to define custom tasks. Are there other options to periodically execute a task and have this setting saved permanently?
Many thanks!
Re: Crontab entries lost after reboot
You can try to change and save the settings use this command vi /etc/crontabs/root. The settings will not be lost with it after rebooting.
