Drive not detected in F2-210
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks.
AndyB
Post by AndyB »
A couple of issues with USB backup on a F2-210. After any kind of power outage (either mains, or manual powering down), my USB HDD (despite spinning up and showing a power light) isn't seen by the TNAS. I have to physically unplug and reconnect the drive each time before the system will see it.
Furthermore, and more annoyingly, the scheduled backup tasks that I have will regularly show "USB device has been removed" and show a backup destination of "USB # /" instead of "USB #1 /directory" as they should. The only way I've found to resolve this is to delete and recreate the backup tasks. Is this a known issue, and will there be any support and development on the Fx-210 devices to resolve this? The drive is a 1TB Samsung Story Station, formatted as ext4.
IrisLi
Re: Drive not detected in F2-210
Post by IrisLi »
Sorry for the bad experience. The scheduled task status is related to whether the USB device is mounted or not, if the USB is not mounted, it will show that the USB device is removed. Regarding the backup target display issue, we have fixed it in the latest version of USB Copy. However, the system needs to be TOS 5 and above. The USB Copy app on TOS 4 will not be updated temporarily.
AndyB
Post by AndyB »
TMqiky wrote: 02 Dec 2024, 19:55 if the USB is not mounted, it will show that the USB device is removed.
The issue is however, that even if the drive is reconnected (and this can be validated by browsing in File Manager, though I don't recommend doing that), the tasks don't appear to reinitialise, and once they're in the "not mounted" status, I've not found any way to get them working again.
GevinKe
Post by GevinKe »
AndyB wrote: 02 Dec 2024, 22:12
We sincerely apologize for the inconvenience caused. Regarding the application updates for the TOS4 system, we currently do not have any updates planned. We recommend upgrading to a newer version of the system to enhance your experience, but unfortunately, the F2-210 is limited to using TOS4. Thank you for your patience and understanding.
crisisacting
Post by crisisacting »
TMgevin wrote: 03 Dec 2024, 09:42 We sincerely apologize for the inconvenience caused. Regarding the application updates for the TOS4 system, we currently do not have any updates planned. We recommend upgrading to a newer version of the system to enhance your experience, but unfortunately, the F2-210 is limited to using TOS4. Thank you for your patience and understanding.
Is this official acknowledgement that there will be no TOS 5.× for the 210 series devices‽
If so, please make an official announcement @ viewforum.php?f=7&sid=157da66281e19351b6363a2b480a31cf so it's clearly visible for all owners of these devices; it was speculated by other staff on this forum that there could be a future update to newer TOS & many have patiently waited for that.
AndyB
Post by AndyB »
crisisacting wrote: 03 Dec 2024, 10:58
Not only is there no TOS 5, it sounds like there will be no further updates. So all the outstanding issues, including some that they acknowledged over a year ago and were passing to the project team to work on a solution, will remain.
Forget all the extra claimed functionality that the 210's are meant to have. If you want anything other than a basic NAS on your own network, look elsewhere.
GevinKe
Post by GevinKe »
We sincerely apologize for any misunderstanding caused by our previous reply. Currently, we have not received any update plans regarding the F2-210. Therefore, this reply should not be regarded as an official announcement. For the most accurate update information, we recommend closely following the "News & Announcements" section.
Return to “USB Copy”
