Android app - Failed to connect
MiXAL
Finland
Post by MiXAL »
It says that I should be able to connect with ID, but with or without ; in the and all I get is Failed to connect.
I think that this would only work locally the best and I need some dyndns in order to connect from remote?
I'm I right on that?
Re: Android app - Failed to connect
TOS version and TNAS mobile app version?
MiXAL
Finland
Post by MiXAL »
Seems that there are different versions. Version on Play store did not work at all, but one from TM downloads work. App folders are not user friendly as you see. App is 2.4.20 and TOS 4.2.44-
