Hi there,
What current terramaster devices are compatible with drives set up to the f5-220? I need to replace my f5-220 and no it sue the best option for putting my current hard drives into with little setup.
F5-220 compatible devices
- crisisacting
- Silver Member
Re: F5-220 compatible devices
Technically, any actively sold ×86/×64 TNAS, but if you want to use current TOS 6 builds, it would already need to have the larger 8 GB system partition to possibly upgrade beyond TOS 5.1.××× …
I recommend that you purchase an F4-424, which is a newer model, and then install the new system using one or two new hard drives. After that, you can back up the data from your F5-220 to the newly purchased F4-424. The hard drives originally installed in the F5-220 can be formatted and then installed in the F4-424 for continued use.
