So, immediately after reboot the kernel messages contain a warning about the filesystem not being checked:
[Sun Aug 2 13:50:29 2020] EXT4-fs (dm-0): warning: mounting unchecked fs, running e2fsck is recommended
[Sun Aug 2 13:50:29 2020] EXT4-fs (dm-0): mounted filesystem without journal. Opts: user_xattr,acl,usrjquota=quota.user,grpjquota=quota.group,jqfmt=vfsv1
Those lines appear when you type "dmesg" at the command prompt.
How do you tell the F2-210 NAS to check the filesystem in the GUI?
Thanks much.
F2-210 -- Warning: unchecked fs
Re: F2-210 -- Warning: unchecked fs
hi, thank you for your report.
The file system checking runs by default when every reboot. We will check here and come back to your soon.
