Hi everyone
I recently purchased the D8 Hybrid. I am using it with 3 HDDs and would like to connect 2 additional NVMe drives. Unfortunately, they are not visible in any slot. For example, I connect a WD 500GB M.2 SATA SSD Blue (manufacturer code WDS500G2B0B). I have tested every slot, but it does not work. These disk are not visible in Disk Utility also (I'm using macOS). What can I do next?
D8 Hybrid - SSD are not visible
Re: D8 Hybrid - SSD are not visible
Hah, no, ofc no - my bad, It's not SATA of course
WDS500G2B0B is WdD Blue Ssd 500Gb M.2 disk.
According https://www.westerndigital.com/en-za/pr ... DS500G2B0B is a SATA Drive with M2 interface. This will not work in TM NVME Slots
main: T9-450
