Migrating from other brand NAS to F6-424
isriza
Singapore
Post by isriza »
Hi all,
I hope I post in the correct forum. I am considering replacing my old Synology ( 2x 4TB: RAID 5) and Netgear (4x4TB: X-RAID) with F6-424, but I still have doubts in the migration process, as I want to keep and use all the discs that I have.
So far, I am thinking of doing the following:
1. Use a new 4 TB disc (Disc A) as a backup and copy the data from Synology, which contains only half the total capacity, to disc A.
2. Then, I'll move the two discs from Synology to create a new volume on F6-424 in RAID 5. (F6 has 2 Discs)
3. Copy back the data from Disc A to two discs in F6-424.
4. Copy the data from Netgear until I have more space in Netgear, and replace one disc on Netgear (Disc B) with the Disc A
5. Install Disc B to F6-424 and continue to copy the rest of the data from Netgear to F6-242. These three discs are enough to hold all my data from Synology and Netgear. (F6 has 3 discs)
6. Lastly, I'll add the remaining discs (3 discs, excluding Disc A) to the F6-242.
7. Finale: I shall have back all six discs from Synology and Netgear on F6-242.
Does the plan make sense? Or can you suggest a better approach?
Thanks a lot.
Riza
Re: Migrating from other brand NAS to F6-424
I'm not sure I followed all that (did you miss out steps on wiping old drives before installing in 424?).
However, consider using Traid instead of Raid 5 (step 2) as I think this format is easier to add/expand than raid 5.
Yes, use your disk A as initial backup. Install/format 2 drives as Traid then copy off A. Add A to Traid - this will give you 8TB in effectively Raid5.
Copy across rest of your data.
{NB Raid 5 on 2 drives is not really a 'thing' - Traid on 2 drives IS a Raid1 mirror. Traid on 1 drive is possible with an add/expand later.
Drive array types are not necessarily interchangeable across devices. TNAS may do things differently to your other devices.
Just my 2p worth.
Pressita1947
Australia
Post by Pressita1947 »
Hi Riza, your plan makes sense! Make sure to backup your data and check the compatibility of your drives before proceeding to avoid any trouble. Good luck! 8-)
GunSpinHave a nice day!
