Applicable Models:
All TNAS models
Applicable Versions:
TOS 4/5/6
Supported Models:
The standard configuration of TNAS devices only supports wired network connection. However, in order to meet the needs of users in different scenarios, users can purchase their own WI-FI adapter to connect to the wireless network. Its WI-FI adapter only supports products equipped with Realtek RTL8812AU and RTL8812BU chips.
Purchase Reference Link:
For your convenience, we have provided the following reference purchase links on Amazon shopping platform:
Realtek RTL8812AU:
Link 1
Link 2
Realtek RTL8812BU:
Link 1
Link 2
Notes:
1. Compatibility: Please purchase a wireless network card model that is compatible with the recommended wireless network card.
2. Installation and Configuration: The wireless network card is installed according to the instructions and configured accordingly in the TOS system to ensure that the wireless network card can work properly.
3. Stable performance: The stability of wireless connection is inferior to wired connection, if you encounter slow speed or drop problems under wireless connection, please switch to wired network to verify the troubleshooting.
What models of wireless network card do TNAS products support?
Re: What models of wireless network card do TNAS products support?
Thanks for the info. Unfortunately, if I wanted such a device I (and probably many others) would not be buying from Amazon.com
