Assistance Needed: Multiple 404 Errors and WebSocket Issues in TOS 6 (Zoraxy Reverse Proxy)
Roman
Austria
Post by Roman »
Hello everyone,
I'm encountering a series of issues on my TerraMaster NAS running TOS 6, which seem to arise when I access the NAS through a Zoraxy reverse proxy with an letsEncrypt certificate.
Any insights on resolving these issues would be highly appreciated.
Problem Summary:
When accessing the NAS via the Zoraxy reverse proxy, I see repeated errors in the console, including failed WebSocket connections and numerous 404 errors when attempting to load various resources. Here’s a breakdown of the primary errors:
WebSocket Connection Errors: Fails to connect to the WebSocket endpoint (wss://my-domain.../events/rpc/ws).
404 Not Found: Many resources, such as JavaScript chunks, images, and JSON files, return 404 errors when accessed via the proxy.
MIME Type Mismatch: Several scripts are blocked due to MIME type issues (text/plain instead of expected script type).
Service Worker Issues: Error registering a ServiceWorker due to Content Security Policy (CSP) restrictions, especially for scripts from Google’s CDN.
Uncaught Type Errors: Various JavaScript errors where properties are read from undefined variables.
Here are some examples of the errors:
  • Restarted the NAS
  • Ensured all TOS updates were installed
  • Websocket Support is enabled in Zoraxy
  • everything is working with IP
  • Zoraxy is running on a mini PC in the same network , Other services (proxmox,portainer,...) work perfect with Zoraxy and letsEncrypt
Has anyone experienced similar issues when using Zoraxy or another reverse proxy with their TerraMaster NAS?
Thank you for any help you can provide!
T6-424 Max - 64 GB DDR5 - 2x4TB NVME - 6x4TB SSD
T6-424 Max - 64 GB DDR5 - 2x4TB NVME - 6x18TB HDD
Re: Assistance Needed: Multiple 404 Errors and WebSocket Issues in TOS 6 (Zoraxy Reverse Proxy)
We will verify what you describe. If there is indeed an issue, it will be attempted to be resolved in a future version.
Return to “Network”
