qnap to terramaster backup  [SOLVED]
Discuss understanding the various backup tools available and choosing the one that's right for you
bobs
Australia
Post by bobs »
Hi
We have a Qnap ts-251+ which is currently doing a daily incremental back up to a Qnap ts-212 (the ts-212 runs for about 2.5 hours per day).
Unfortunately the ts-212 has developed a fault where it doesn't turn on at the scheduled time and even occasionally doesn't start with the power button requiring a power disconnect- reconnect to get it to run. We originally had the backup going to a ts-112 which also developed the same problem.
I am looking for a replacement for the ts-212 and saw the Terramaster F2-212, am I correct in thinking the TS-251+ will readily perform incremental backups to the Terramaster F2-212?
Regards,
Bob
EthanLiu
Re: qnap to terramaster backup  [SOLVED]
Post by EthanLiu »
bobs wrote: 07 Nov 2024, 21:02
I'm delighted that you've chosen our product. You can refer to the following link to find out which backup solution is suitable for your device.
viewtopic.php?t=6093
Based on your description, we recommend TFM Backup, Centralized Backup, or Rsync Backup.
Return to “How to back up? Which one is right for me?”
