Good morning, I need to start automatically urbackup container after booting TOR.
I try to flag autostart option inside container but it isn't works.
Can i solve this?
Thanks,
Flexline
Docker - auto start container
sports_wook
Re: Docker - auto start container
I've noticed this as well and it needs to be fixed. If anyone has a workaround or solution please post it here.
Me too, autostart container does not work.
We will check whether it's ok here and get back to you later.
how is this going?
We have reported this problem to our product team.This will attempt to be fixed in a later version.
Do you guys have a target date for the correction of the autostart flag ?
It was working before and this regression is kind of annoying for me.
Is there a way to launch it automatically from the command line when the NAS starts ?
New update is coming next week.
Ok good news, meanwhile, here is a workaround: running the followind command will do the trick (for an already running containter - as on my side the daemon was up and running):
See : https://docs.docker.com/config/containe ... matically/
Cheers
docker update --restart unless-stopped <container_name>Cheers
