This may seem stupid question, but all the posts in the "Update Notice" section suggest that the only way to get to TOS 6 is via TOS 5.
I am currently on 4.2.44.
I appreciate TOS 5 is a complete format and re-install, which is not really a problem.
But, copying my data back on is going to be time consuming. Around 4.5Tb, via USB
So, is it possible to do a vanilla install of TOS 6?
Reading through the updat posts, it would seem I have do the following:
Format and install 5.0.120 -> 5.0.176 -> 5.1.24 -> 5.1.40 -> 5.1.145 -> 6.0.229 -> 6.0.530
NOTE: I can not even find a 5.1.145
Is it possible to clean install TOS 6?
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
TNAS F5-221
1X WD 4TB USB
Re: Is it possible to clean install TOS 6?
After backing up your data to other devices, are you going to format the disks and install TOS6 directly?
You have been privately informed of the appropriate method for your situation. There are many things to be aware of. Please do not spread it, so that it will not be misused by individual customers and cause malfunction.
