Unraid - auto power on after power failure
I have the F4-424 PRO. I played around with TOS 5 for a while but was never a big fan so I switched to Unraid and I love it. There was one feature of TOS that I thought was good and that was the toggle to turn on auto power on when power is restored after a power outage. I don't see the same option in Unraid. Some others have said check the BIOS. Before I find a monitor and keyboard to connect I thought I would ask here. Thanks!
Re: Unraid - auto power on after power failure
My F2-424 (standard) has the bios setting at Advanced > Power Management features.
(Options == Last State, Power On, Power off)
You can also set WOL options here.
Disclaimer: May depend on the actual Bios installed or YMMV
Looks like Tos has a bit of trickery built in since the actual bios setting on my machine did not reflect the GUI setting. Thanks
for the reminder.
for the reminder.
