web file manager progress bar
McCoder67
Denmark
Post by McCoder67 »
I'm copying rather big amounts of data between two volumes using the web file manager (TOS5), but the progress bar "window" disappeared :shock:
Is there any way to get it back ? Or do i just have to look at the disk bandwidth utilization in the in the Resource Monitor to know when the copying is done ?
Re: web file manager progress bar
Please open File Manger > File Task > Background Tasks and check if your transfer task is still there?
In Control Panel > Resource Monitor, can you still see the cp command active? What is the load/CPU usage/RAM usage at this time?
McCoder67
Denmark
Post by McCoder67 »
yup, the File Task did it, thank you very much :)
Return to “File Services”
