TOS 6.0.519 (X86) is Released for Update
TMLeeh
Post by TMLeeh »
Target Users:
Users currently running TOS 6.0.500 or later versions.
Note:Updates for other users will be released gradually. Please stay tuned for update notifications.
Warning!
  • This version is not compatible with the Beta version's permissions.If permissions cannot be inherited after the update, you need to temporarily assign other permissions and then reset them to the ones you need.
Update Notes
Bug fixes:
1. Fixed the issue that Docker Manager could not download images properly after enabling SPC.
2. Fixed the issue that the Docker Manager icon disappeared from the TOS desktop after an update.
3. Fixed the issue that shared files could not be downloaded properly.
4. Fixed the issue that the prompt message was incorrect when restoring file system snapshots while mounting encrypted shared folders.
5. Fixed the issue that Rsync could not be enabled properly after enabling SPC.
6. Fixed the issue that new volumes could not be created after enabling SPC.
7. Fixed the issue that new features did not display properly after updating applications.
8. Fixed the issue that PPPoE would obtain VPN network parameters.
9. Fixed the issue that IP usage was inaccurately assessed when modifying IP addresses.
10. Fixed the issue that the TOS desktop occasionally displayed the "TCP/IP settings in progress" message.
11. Optimized the display effect of the TOS desktop system dashboard.
12. Optimized the style of floating window tooltips within the system.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.003 for Windows OS:
https://download3.terra-master.com/Apps ... .2.003.exe
Download TNAS PC 5.1.202 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .1.202.pkg
Download TNAS PC 5.1.202 for macOS (ARM architecture):
Download TNAS Mobile 3.2.47 for Android:
https://download2.terra-master.com/TNAS ... 3.2.47.apk
TNAS Mobile for iOS: Download from the iOS App Store.
Re: TOS 6.0.519 (X86) is Released for Update
So, is this version .519 the same as the version that was pushed earlier or has it been 'fixed'. I refer to
viewtopic.php?p=39143#p39143
If this has been changed how do I download THIS version when my nas thinks it already has it :?: :?:
Gremlin wrote: ↑23 Oct 2024, 21:18
This is the same version as the one you previously updated.
tienduoc
Vietnam
Post by tienduoc »
How can I upgrade from TOS 5 to this version? I'm using F2-423
Thanks!
TMRyan wrote: ↑23 Oct 2024, 23:49
Thank you. I take it the issue mentioned was a red herring.
jpeckinp
Post by jpeckinp »
Noticed I had to setup Hyper Cache again.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
joka388
Austria
Post by joka388 »
Works fine on my F2-221
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
monkeyboy72
Post by monkeyboy72 »
Hi is there any news on when TOS6 will be officially available via the downloads page for other models, I see some models already have access?, thanks.
titan5
Post by titan5 »
At the moment it seems the only ones who can upgrade to 6.0.519 are those with previous TOS 6.x versions.
Where are the clear instructions for TOS 5.x users to upgrade to an official TOS 6.x version without having to load previous Beta versions?
When will it be clear which devices, like my F5-221, will support TOS 6.x and how do we confirm our serial numbers are suitable for upgrading to TOS 6.x?
I have asked this before in other threads with no answers.
titan5 wrote: ↑25 Oct 2024, 05:18 I have asked this before in other threads with no answers.
To be fair, there have been plenty of answers to several users. "Wait for the instructions to be released" or words to that effect. I'm getting tired of people asking the same question over and over and ignoring the answers.
