Update Docker Engine
Discussion about Docker
pixelspusher
Post by pixelspusher »
Seems like we're stuck with a TWO YEAR old version of Docker Engine. Is there a reliable way to update it to the latest?
TOS is on 20.10.17 (from 2022-06-06) when the current version is 27.3.1.
DCCentR
Re: Update Docker Engine
Post by DCCentR »
I also like to see more recent versions of Docker Engine and Portainer
F4-424 Pro
TMeric
Post by TMeric »
Both Docker and Docker Engine will be updated in the near future. Please be patient and wait for the updates.
DCCentR
Post by DCCentR »
TMeric wrote: ↑13 Nov 2024, 21:39 Both Docker and Docker Engine will be updated in the near future. Please be patient and wait for the updates.
But not Portainer? :(
F4-424 Pro
bugacha
Algeria
Post by bugacha »
I see docker is updated today to
docker --version
Docker version 27.2.1, build 9e34c9b
Good job @TerraMaster team
fcs001fcs
Post by fcs001fcs »
Updated Docker Engine and Docker Manager Apps today.
Docker Manager 2.1.2 has problem with the graphs in "Overview", both "Total CPU Usage" and "Total RAM Usage". CPU is zero most times and RAM is way too low.
TM: Kindly investigated this error and fix for the next version. Thanks.
Otherwise, I updated to Docker Engine 27.2.1 and Docker Manager 2.1.2 and they seem to be working OK. I use a standalone Portainer (not TOS App) and my containers seem to all work OK. I did have to reinstall an "Open Speed Test" stack/container due to permissions errors in the log, but a very minor issue.
F4-423 - 2 x12TB & 1x14TB & 1x16TB - BTRFS TRAID
fcs001fcs
Post by fcs001fcs »
fcs001fcs wrote: ↑03 Dec 2024, 07:24 Updated Docker Engine and Docker Manager Apps today.
Sorry, forgot to mention I am on TOS 6.0.535
TMeric
Post by TMeric »
Thank you for your feedback. We will verify the issue you mentioned as soon as possible.
Phildefer
France
Post by Phildefer »
Since the update of the Docker engine when I want to open the console on my container with Portainer I have this message : Unable to retrieve image. details
fcs001fcs
Post by fcs001fcs »
TMeric wrote: ↑03 Dec 2024, 21:51
When I disable (uncheck) "Enable continuous resource monitoring", I get some data points on the graph.
I checked the storage location listed in the "Resource monitoring" settings and that file "system.db" does not exist. The DB that is listed in that directory is "resource-monitor.db". I think this may be the problem.
I do not have the ability in the GUI to change the "Storage location" as it is greyed-out for me. See attached screenshot.
TM: How do I set the correct "Storage location" in the "Resource monitoring" settings?
Return to “Docker”
