Updating an application (Emby)
Isembard
Post by Isembard »
I'm trying to update the application 'Emby'.
The one on the Terramaster server appears to be an old one ( 4.7.5.2)
I downloaded the latest versio from the Emby site, file name is "emby_TOS5_APP_4.8.10.0_x86_64.tpk", so presumably version 4.8.10.0.
How do install this into the TOS Desktop, instead of the one on the Terraster server?
Thanks in advance for any help.
Re: Updating an application (Emby)
If I am correct you have an F2-210 model nas. This is an Arm based device. the Emby app update you reference is for an Intel based device so would not be compatible.
Frustrated Beta Tester!!!
Isembard
Post by Isembard »
Hi Gremlin,
I downloaded what I think is the correct file, "emby_TOS5_APP_4.8.10.0_aarch64.tpk" from the Emby site.
How do I use this file to update my system?
Thanks in advance.
Sorry, I have no idea. I just pointed out what I thought was an obvious inconsistency.
Sorry, I can't understand what you mean by “TOS Desktop” and “Terraster server”. You can upload and install tpk manually by going to TOS>Application>Setting.
If you are concerned about the icon on your desktop, you can send the icon to TOS Desktop from Application.
