Multimedia Server does not enable after reboot/start
A TerraMaster app for media transcoding and streaming
Updated to Tos6.0.512 this morning. (all went smoothly)
However, I am still seeing issues with Multimedia Server not being enabled after a shutdown or reboot. (Version 3.2.99)
Now, there is every indication in control panel overview, App Centre, etc that the app is enabled (green tick marks/wording). BUT
when the app itself is opened, the check box for 'enable' is blank. Only after ticking the enable box and applying change does the server truly enable;
ie, indexing starts and and server is visible on network.
And, incidentally, there is still Chinese writing under the top left logo (in English display setting.)
EthanLiu
Re: Multimedia Server does not enable after reboot/start
Post by EthanLiu »
Gremlin wrote: 13 Oct 2024, 17:59 Updated to Tos6.0.512 this morning. (all went smoothly)
Please make sure that the volume where you have installed the application has sufficient available space. Meanwhile, I will collect the issue you have reported and submit it to our engineers for troubleshooting the cause.
Single volume on single pool - BTRFS. Volume is 1.95TB with only 3.39 GB in use. (yes, that's GigaBytes) :)
I rre-installed MMserver yesterday to verify another factor using an alternative admin name. Now running 6.0.519.
I now see in Monitor
"Started MultiMedia Server.service"
and MMserver is enabled on reboot.
Return to “Multimedia Server”
