Users currently running TOS 6.0.500 or later versions.
Note:Updates for other users will be released gradually. Please stay tuned for update notifications.
Warning!
- This version is not compatible with the Beta version's permissions.If permissions cannot be inherited after the update, you need to temporarily assign other permissions and then reset them to the ones you need.
Update Notes
Bug fixes:
1. Fixed the issue that wsdd information was not updated in a timely manner after modifying the SMB workgroup name.
2. Fixed the issue that the device name could not be changed after closing wsdd.
3. Fixed the issue that the network interface page continuously displayed "Setting up" after inserting a wireless network card.
4. Fixed the issue that the buzzer did not sound promptly when the array degraded.
5. Fixed the issue that Docker containers could not be re-enabled after restoring a file system snapshot.
6. Fixed the issue that file permissions and properties for names containing certain special characters could not be set.
7. Fixed the issue that folder replacement permissions could not be set in file management.
8. Fixed the issue that email notifications triggered by abnormal shutdowns sometimes had no content.
9. Fixed several other issues.
10. Optimized file system mount parameters.
11. Optimized the log information collected in debug mode.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.003 for Windows OS:
https://download3.terra-master.com/Apps ... .2.003.exe
Download TNAS PC 5.1.202 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .1.202.pkg
Download TNAS PC 5.1.202 for macOS (ARM architecture):
Download TNAS Mobile 3.2.47 for Android:
https://download2.terra-master.com/TNAS ... 3.2.47.apk
TNAS Mobile for iOS: Download from the iOS App Store.
