windows11 with virtualbox - This computer cannot run windows 11
sylon
Spain
Post by sylon »
Hello everyone,
I have a F4-424 pro and when I try to install windows11 with virtualbox it tells me that “This computer cannot run windows 11, it does not meet the minimum requirements”.
How can I install it?
crisisacting
Re: windows11 with virtualbox - This computer cannot run windows 11
Post by crisisacting »
You likely need to disable Windows 11 installer from checking for TPM 2.0 along with other requirements for it to install as a VM under virtualbox.
sylon
Spain
Post by sylon »
I will try it, thanks
Return to “Virtual Machines”
