.. a ResetFunction under PowerOptions and ScheduledTasks.
Better than schedule a PowerOFF and hope the system will wake up..
Reset Function
Reset Function
F5-221 - TOS7.0.1140 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1140 - 2x3TB JBOD - 1x4TB Single USB
Re: Reset Function
I don't quite understand your requirements. Could you please provide a more detailed description?
Re: Reset Function
(Thanks for your fast reply, mine reply didn't come through - so I try again)
Under PowerOptions and ScheduledTasks I would like to see a schedulable Restart/Reset.
Now I schedule a PowerOFF, have to estimate how long it will take, then schedule a PowerON after that.
Especially welcome since my 2nd NAS (F2-221 TOS 6.0.507 ) from day 1 refused to wake up by itself, PowerON doesn't work, probably a BIOS thingy ?
The same goes for scheduling applications/services. A restart option would be so much easier..
Re: Reset Function
1.Have sent this request back to the product department. Thank you for your help.
2.You can check the BIOS settings of the NAS to ensure that related features such as Wake on LAN (WoL) or AC Recovery (AC Back Function) are enabled. These functions usually allow the device to wake up automatically when it receives a network signal or power restoration.
