I wanted to install Docker Manager from the App Center but I have an error "Operation Failed".
Docker Engine has been installed but the download of Docker Manager doesn't start.
F4-424 Pro TOS 5.1.145
Docker Engine 20.10.17 installed
Docker Manager 2.0.16 cannot install
This is a fresh NAS with nothing installed.
I haven't found similar issue on the forum.
Cannot Install Docker Manager TOS 5.1
Re: Cannot Install Docker Manager TOS 5.1
Have you tried swapping the download and installation order? Uninstall DockerEngine first and directly install DockerManager to check if it can be enabled successfully.
Ok I don't know but after a few more tries it installed. So it's ok now
