TOS 6.0.507 (X86) is Released for Update
Target Users:
Users currently running TOS 6.0.500 or later versions.
Note:Updates for other users will be released gradually. Please stay tuned for update notifications.
Warning!
  • This version is not compatible with the Beta version's permissions.If permissions cannot be inherited after the update, you need to temporarily assign other permissions and then reset them to the ones you need.
Update Notes
Bug fixes:
1. Fixed the issue that system dashboard information loads slowly in the absence of a network.
2. Fixed the issue that normal users could not access USB devices properly after setting permissions.
3. Fixed the issue that the state of volume and storage pool could occasionally be inconsistent
4. Fixed the issue that IPv6 status was not inherited when deleting a BOND.
5. Fixed the issue that some shared folders could not inherit permissions.
6. Fixed the issue that permissions occasionally displayed incorrectly when uploading folders in file manager.
7. Fixed the issue that the selected time zone during system initialization did not match the displayed system time zone.
8. Fixed the issue that the power-on automatic startup function was abnormal on F8 SSD/F8 SSD Plus.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.003 for Windows OS:
https://download3.terra-master.com/Apps ... .2.003.exe
Download TNAS PC 5.1.202 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .1.202.pkg
Download TNAS PC 5.1.202 for macOS (ARM architecture):
Download TNAS Mobile 3.2.47 for Android:
https://download2.terra-master.com/TNAS ... 3.2.47.apk
TNAS Mobile for iOS: Download from the iOS App Store.
norman0
Germany
Re: TOS 6.0.507 (X86) is Released for Update
Post by norman0 »
Is this version work on the F2-220?
F2-220 4GB + 2*Seagate IronWolf 4TB
norman0 wrote: 30 Sep 2024, 12:43 Is this version work on the F2-220?
This model no longer supports using TOS6.
DCCentR
Post by DCCentR »
Any ETA on TOS6 installation package for F4-424 Pro?
F4-424 Pro
tanktarta
Post by tanktarta »
*sighs*
After several smooth(ish) upgrades in the beta versions lulled me into a false sense of security, going from 6.0.500 to 6.0.507 appears to have completely broken everything for me yet again.
I can no longer access the web user interface on the expected ports (I had "released" 80/443), the default ports don't work either, always saying "Unable to Connect"
While I can connect to the SSH port, I cannot authenticate. Neither with my previous password, or using an SSH key that I had added to my "superuser" account so password with SSH was not required. It looks like yet again TOS has messed up my root account somehow.
It looks like my only choice is probably going to have to be hooking it up to a monitor and try and work out whats going on.
I am trying to be patient with TOS. I do, and want to continue liking it. But I just don't understand as to how it can be this flaky at this stage and my trust is waning.
It would be great to install a minor version upgrade and still be able to access the NAS afterwards :-|
tanktarta wrote: 30 Sep 2024, 17:07
Are you logging into the terminal using the user you created when you initialized the system? After the update, can you use TNAS PC to search and then jump to the browser? Have you tried restarting the TNAS? Would it be convenient for you to contact our online customer service now so that we can remotely check it for you?
After the update, can you use TNAS PC to search? If so, you can try using TNAS PC to click and jump. Did you make any modifications to the system files in the terminal before the update? If you did, you might be redirected to the system initialization page after the update. You can log into the terminal using the account created during the system initialization. If restarting doesn't work, if it's convenient for you, you can contact us for remote troubleshooting.
ellowsmile
Post by ellowsmile »
After updating 6.0.500 and 6.0.507, I can't add a long test for my HDDs. Only quick or long. I can't use both at the same time. This problem wasn't in beta version 6.0.460
F4-423
ellowsmile
I added the wrong screenshot.
F4-423
tanktarta
Post by tanktarta »
TMRyan wrote: 30 Sep 2024, 17:40 Are you logging into the terminal using the user you created when you initialized the system?
Yes. I chose the name "superuser" for this.
TMRyan wrote: 30 Sep 2024, 17:40 Have you tried restarting the TNAS?
Yes I tried a restart.
TMRyan wrote: 30 Sep 2024, 17:40 Would it be convenient for you to contact our online customer service now so that we can remotely check it for you?
That would be possible if it comes to it, see next reply. FWIW, you have already rescued me once before with what appears to be a very similar problem.
TMRyan wrote: 30 Sep 2024, 17:40 After the update, can you use TNAS PC to search and then jump to the browser?
Yes! It seems I can. This is the first time i've used the TNAS PC. Ordinarily I just connect from Linux using browser or SSH. Screenshots attached.
So it is saying the TNAS is uninitialised. It really isn't! This looks scary. If I continue, is my existing data safe?
