SMB filling up messages log
Scrums
Post by Scrums »
I had a look at the log directory using SSH:
[root@unnamedsrv log]# ls -l
total 488
drwxr-xr-x 2 root root 60 Jan 28 12:56 audit
-rw-r--r-- 1 root root 2084 Jan 31 06:16 auth.log
drwxr-xr-x 3 root root 60 Nov 26 02:34 cron
-rw-r--r-- 1 root root 143159 Jan 31 09:33 crond.log
-rw-r--r-- 1 root root 48287 Nov 26 02:34 dovecot-info.log
-rw-r--r-- 1 root root 16877 Nov 26 02:34 dovecot.log
drwxr-xr-x 2 root root 80 Nov 26 02:34 httpd
drwxr-xr-x 2 root root 40 Nov 26 02:34 inadyn
-rw-r--r-- 1 root root 220152 Jan 31 09:32 messages
-rw-r--r-- 1 root root 2028 Nov 26 02:34 minidlna.log
-rw-r--r-- 1 root root 444 Jan 28 12:57 mntdata.log
-rw-r--r-- 1 root root 2912 Jan 31 09:32 msgcenter_Tue_Jan_28_12_57_45_2020.log
-rw-r--r-- 1 root root 7453 Nov 26 02:34 mt-daapd.log
drwxr-xr-x 7 root root 180 Nov 26 02:34 nginx
drwxr-xr-x 2 root root 60 Nov 26 02:34 noip2
drwxr-xr-x 2 root root 60 Nov 26 02:34 phddns
drwxr-xr-x 2 root root 60 Jan 28 12:56 php-fpm
drwxr-xr-x 2 redis redis 60 Jan 28 12:57 redis
-rw-r--r-- 1 root root 29 Nov 26 02:34 resolv.conf
drwxr-xr-x 3 root root 100 Jan 28 12:57 samba
-rw-r--r-- 1 root root 4225 Jan 29 07:57 scripts.log
drwxr-xr-x 2 root root 40 Nov 26 02:34 session
-rw-r--r-- 1 root root 0 Nov 26 02:34 sshd
drwxr-xr-x 2 root root 120 Nov 26 02:34 subsys
-rw-r--r-- 1 root root 1389 Nov 26 02:34 upnp.xml
-rw-r--r-- 1 root root 23470 Jan 31 09:25 user.log
lrwxrwxrwx 1 root root 14 Jan 28 15:07 zlog -> /mnt/md1/@zlog
[root@unnamedsrv log]# cat messages
Jan 31 09:25:01 unnamedsrv TOS_STANDBY: Wake up now...
Jan 31 09:32:31 unnamedsrv smbd[4303]: [2020/01/31 09:32:31.592773, 0] ../source3/printing/print_standard.c:71(std_pcap_cache_reload)
Jan 31 09:32:31 unnamedsrv smbd[4303]: Unable to open printcap file /etc/printcap for read!
(This seems to happen constantly,Unable to open printcap file /etc/printcap for read!
To stop this the config file needs to be updated:
https://schmidi2itblog.wordpress.com/20 ... -for-read/
Can this be included in the next build of TOS?
Scrums
Re: SMB filling up messages log
Post by Scrums »
I tried making this change myself to no avail :-(
onejedi
Post by onejedi »
Hmm, this is probably why my SMB logs take so long to load in TOS, causing high CPU usage for a while (viewtopic.php?f=71&t=57)
mathygreen
Post by mathygreen »
i have the same problem
OPM load in seconds.... the problem is that after it loads SMB/CIFS takes too long to come up.
how can i solve this...
How long does it take you to start SMB service? Could you please provide the TNAS, hard disk model and TOS version?
mathygreen
TerraMaster U4-211
hard disk 1 terabyte and TOS 4.0
Will fix it in future release.
Return to “File Services”
