Creating distinct Pool/Volume on HDD (Tos6 Beta 6.0.460)
I have installed a clean (wiped) HDD in my F2-424 with 2 Nvme drives in Traid carrying the os and Volume1/Pool1 (BTRFS)
If I then opt to install a second volume (Volume2) on the new HDD (Still with BTRFS and Traid) the action results in os partitions being automatically written to the hdd and the hdd becomes (??default??) a system drive. {Pool2 being created automatically). This shows itself on re-boot.
The side effect is that one of the nvme drives is 'stripped' of it's system drive status. Previous testing along these lines tells me that configuration changes after such an event are not written to the non-system drive nvme despite the os partitions still being visible. Even, it still is apparently part of the raid1 mirror.
xxxxxxxx@NAS-T:~# lsblk
NAME          MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
sda             8:0    0   5.5T  0 disk
    sda1          8:1    0   5.5T  0 part
sdb             8:16   0   5.5T  0 disk
     sdb1          8:17   0   285M  0 part
     sdb2          8:18   0   7.6G  0 part
         md9         9:9    0   7.6G  0 raid1 /
     sdb3          8:19   0   1.9G  0 part
         md8         9:8    0   1.9G  0 raid1 [SWAP]
     sdb4          8:20   0   5.4T  0 part
       md1         9:1    0   5.4T  0 raid1
         vg1-lv1 252:1    0   5.4T  0 lvm   /Volume2
nbd0           43:0    0     0B  0 disk
nbd1           43:32   0     0B  0 disk
nbd2           43:64   0     0B  0 disk
nbd3           43:96   0     0B  0 disk
nbd4           43:128  0     0B  0 disk
nbd5           43:160  0     0B  0 disk
nbd6           43:192  0     0B  0 disk
nbd7           43:224  0     0B  0 disk
sdzb          259:0    0 465.8G  0 disk
    sdzb1       259:1    0   285M  0 part
    sdzb2       259:2    0   7.6G  0 part
   sdzb3       259:3    0   1.9G  0 part
   sdzb4       259:4    0 455.9G  0 part
      md0         9:0    0 455.8G  0 raid1
        vg0-lv0 252:0    0 455.8G  0 lvm   /home
                                         /Volume1
sdza          259:5    0 465.8G  0 disk
   sdza1       259:6    0   285M  0 part
   sdza2       259:7    0   7.6G  0 part
    sdza3       259:8    0   1.9G  0 part
     sdza4       259:9    0 455.9G  0 part
                                         /Volume1
nbd8           43:256  0     0B  0 disk
nbd9           43:288  0     0B  0 disk
nbd10          43:320  0     0B  0 disk
nbd11          43:352  0     0B  0 disk
nbd12          43:384  0     0B  0 disk
nbd13          43:416  0     0B  0 disk
nbd14          43:448  0     0B  0 disk
nbd15          43:480  0     0B  0 disk
[edited slightly to remove unprintable characters ]
[sda is an unmounted hdd, subject of another thread]
The aim, of course is to maintain the initially chosen drives as system drives and NOT have the os partitions created on the added hdd.
Answers on a post-card.
F5-221 TOS7.0.1105 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1105 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1105 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1105 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
Re: Creating distinct Pool/Volume on HDD (Tos6 Beta 6.0.460)
The phenomenon you mentioned has been reproduced. Our project team is checking and fixing it.
OK, Thanks.
FYI a possible side effect is that the system cannot recognise a volume on which to install apps. the selection box is blank (despite originally being set) and will not recognise a new selection (box returns to blank).
Deleted Volume2, Pool2
reboot -> Volume 2 reappears.
Wiped HDD2 -> {Observed system drive reallocation in GUI} -> {Observed in console = 'missing drive, running on one only' or something similar}
- > reboot
{Noted raid being rebuilt for Nvme drives in console}
GUI shows 'correct' system drives
Noted some apps installed for testing had disappeared from desktop. {Looking further at that}
Thank you. We'll keep an eye out for this possible scenario you mentioned.
Return to “Initialization”
